Can the Bravia KD50SD8005 4K curved tv software be updated to download the Freeview Play and UK-TV Play apps ?
Had no success so far.
Have you looked for these in the Google Play TV Store on the set? If they are not there you can’t do it, at least not straightforwardly.
But I don’t think Freeview Play is an app, anyway. It’s a whole UI, which a TV either comes with or it doesn’t, and these sets come with YouView, a rival to Freeview Play, albeit one without the UK TV Player, instead.
