Bought this TV in January. But just cannot display the freeview internet data channels. 2 Other TV's in the house receive them perfectly.
I have tried your troubleshooting steps but all to no avail. I am still unable to display the data channels as below
251 365 Travel
252 Kiss Chat & Date
253 proud Dating
263 Sonlife
264 Vision TV
265 On Demand 365
269 Arise
271 Channel Box
The Guide for all these above channels is populated but when you switch to any of them the data does not load.
My Internet connection is OK as I can receive Netflix and Prime Video perfectly OK.
Any one else suffering from this problem
Hi arfa69, if you're on youView, try gong to apps in settings then YouView and YVservice host, clear cache and data for both of them then force stop them. After that a soft reset then enable YouView. It always worked for me.
No You View in settings
This is to do with the broadcast technology used, the newer Sony TV's can not receive the older version of interactive service channels which is broadcast in MHEG but instead use the much newer hbbTV. Unfortunately most of the channels that are listed in the OP are broadcast using the old technology, as mentioned though, channelbox is beta testing a new hbbTV service. I believe VOD365 is already on the newer system as it works on my XH92, however according to the web page below doesn't use hbbTV yet.
The take up of hbbTV is so slow for some reason. Here's hoping the other channels follow suit and migrate fully.
For info... https://www.freeview.co.uk/help/viewing-ip-channels
Hi arfa69, it's on apps in settings, if it's not there, try showing all apps.
Thanks for that
Let us know if that worked. ^^
Sorry but no. I am incline to agree with the comment made by- bestobadness which I have received similar comments from one of the broadcasters
Hey arfa69, there are more steps to try if you want, but I guess since it's the same message from the broadcasters then it's not worth it I guess!
Thanks for your help and interest but I think I will just sit it out
According to this article, Vision TV was the last one to complete rollout and all should be working since the end of Jan https://rxtvinfo.com/2022/freeview-ip-channels-complete-hbbtv-rollout
For me I can only get
211 - Ketchup TV
212 - Yaaas
265 - On-demand 365
These still won't work
263 - Sonlife
264 - Vision TV
269 - Arise News
271 - Channel Box (it tries to load and a dot appears)
252 - Kiss Chat & Date
253 - Proud Dating
The link posted by beastobadness has had no updates https://www.freeview.co.uk/help/viewing-ip-channels so I'm not clear if its a Freeview or Sony issue.
