Just downloaded and installed via USB. no issues after installation.
From Sony Support site
Benefits and Improvements from the latest update
I agree, it is very distracting. Try the factory reset as it looks like it might have solved the problem on mine, but only time will tell.
Ok may give that a go later 😬
Post your results as it would be really promising if you get the same result as me 👍
