Hi, I am trying to find this firmware update for my sony kd 65xd8599 and note it’s no longer available on the download site. Is it possible to have this sent to me via email please?
As you know Sony have terminated software support for your model of TV as of 26 06 2024.
Check the link here,
If you read the page you will see this.
Scroll to the bottom of the page and click on this,
Contact support
Contact your Sony Support team
Try them see if they are clued up.
If not you may have to wait and see if any owners of the same model have held a copy of the update
that they are willing to share with you probably via a download site, e-mail is a bit ambitious for an update
that may be in the 100's of megabytes or even gigabytes.
Ive posted similar for this version without any result as yet.I have a contact who may be able to help with the file and I'll update if I have any success.Not sure at this juncture whether it will be also suitable for your model but I'll try and clarify if I can.Virtualy impossible to contact Sony for any further advice.
Hey @Jacko1966
The firmware version of your TV: https://tv.update.sony.net/OND/0000/eu/main/PS116287/sony_tvupdate_2015_5457_eub_auth.zip
Hi EMS_M072,
I don't suppose you have a link to the latest firmware for a kdl-50w805c do you please ?
I've really struggled to find it.
Thanks
If you could, I'll be very grateful. Thank you !
@Cheesemaker67 wrote:Hi EMS_M072,
Hi, if you want to tag somebody simply press @ and then select the person from the list, like @Cheesemaker67
