x
? Firmware update to KDL-32WE613 TV
SOLVED
profile.country.GB.title
pandaman77
Explorer
I have had this tv since May last year, it had to have a new main circuit board in Sept., Not good for a Sony product. The fault started with the tv unable to get the BBC red button service though we could get it on the freeview recorder. If the red button was pressed it stopped the numeric key pad from working, eventally the channel would freeze  and no buttons worked. A factory reset did not help. The red button problem has returned so I checked the software version and it says V8.542 which is what it was last year during the problem. The Sony site says there is a firmware update to V8.602 but my tv says it is up to date. My model is listed for the V8.602 update so why can't the tv update it? I was hoping it would update to see if the red button problem could be solved.
1 ACCEPTED SOLUTION
Accepted Solutions
Joe_Dohn
Specialist
Do let us know if that fixed it for you and mark your post as the solution so others can find the solution easily. ^^
6 REPLIES 6
profile.country.DE.title
Peter_S.
Genius
Please check the following support article for further information in regards to the red button behaviour:
https://www.sony.co.uk/electronics/support/televisions-projectors/articles/00257438
pandaman77
Explorer
I am aware that the red button service can  work when connected to the internet. We usually have the wi- fi off as we do not use it much, only 2 or 3 times since last May to watch a missed  programme. The red button service without the internet was working fine until 2 days ago, as I said there must be a fault somewhere as if you press the red button it disables the numerical buttons and it took ages to get them working again. Also any answer to update query? Thanks for replying though.
Joe_Dohn
Specialist
Sometimes the TV is unable to see a new/recent update (sometimes due to it being disconnected for a while, but this isn't really something confirmed AFAIK).
Try the USB stick method mentioned on the download page.
pandaman77
Explorer
Thanks Joe, looks like I will have to try that method.
Joe_Dohn
Specialist
Joe_Dohn
Specialist
