How can I export program list to USB stick on Bravia KD-55XE8096 to sort on PC
settings-channel setup-digital setup-technical setup-programme list transfer
and you need that sony pc editor or whatever the name is
Thanks,
works perfect
does anybody know what format the usb stick has to be keep getting problem with usb write on all my usb drives and ports please help
