I have the Eurosport app loaded on my Sony Bravia (Model BRAVIA 4K UR3) and can play the highlighted programme, but the app doesn’t allow navigation using the remote up/down left/right. Other apps like BBC I Player load and work fine.
Very frustrating. Why doesn’t this work as it should?
Is it necessary to have a Sony original remote or will universal one work? I have the same issue with the navigation
A clone is now working fine for me, I’m using this one purchased from a well known shopping site which referenced my model. - ALLIMITY RM ED045 RM-ED045 Remote Control Replaced for Sony Bravia TV
I have the same problem, I purchased two Sony android TVs in November a Bravia KD43H8505 and a KD65XH9005 I have Eurosport Player downloaded on both.
One of the remote controls allows navigation on both TVs. The other one doesn’t work and won,t navigate left to right etc. I don’t understand this and it’s annoying not to have both working?
Go to Settings > Remotes and Accessories > Buetooth settings and switch Bluetooth to "off". This worked for me and now I have full navigation.
Thanks so much for your advice.That fix completely sorted out the problem.
March 2022 and this is still an issue.... 🤔
Thanks for the workaround. Switching off bluetooth worked for me too (Sony KD-43X89J)
