Hi All,
I have a Sony Android TV model is KD-43XD8099
Can anybody tell me, the max Ethernet speed of the built in socket.
Also can a usb to ethernet adaptor be used on this TV.
Reason I ask is that I have now changed my network speed to 500 MBPS and want the TV to utilise that speed.
2nd Q how can previous SSID's be deleted from the wifi settings ?
TIA
Your TV as any other on the market has a 10/100 ethernet port and your tv being rather old won't support wifi 5ghz to overcome the limit. AFAIK no usb adapter will work
Not that there is any real need for a TV to have a gigabit connection, most popular streaming services using 15mbps for 4K HDR
