Happy weekend all#
My EPG has scrambled its brain.
I dont use youview i use the built in digital tuner to tune in the freeview channels, and its been fine for months then all of a sudden the last few days the EPG has just gone crazy.
I dont know how it happened, all was fine one minute, then it wasnt, the EPG shows all my tuned channels twice for some reason when you bring up the epg, and when you attempt to move down the list it goes as far as BBC2 and wont go further than that!
Ive looked at my saved tuned channel list in settings and that looks fine, shows the channels in the norm correct order so i checked it was only freeview with a saved channel list and it is the rest are not in use at all.
I dont really want to have to delete my channel list and retune the whole stupid thing again.
Hi @graygerman Your TV model number? This very morning Sony has fixed the EPG problem (see posts). Perhaps this is a knock-on consequence. I would report it to Sony Support Consumer Electronics
My model is KD65X89K
Very annoying, this is actually the 2nd time in 8 months its happened, i think its a combination of Sony and the broadcaster making changes, ends up corrupting the epg however i have found what seems to be a solution im about to try
