- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
encryption
After i got a new motherboard on my KD-55x8505c i cant play from the HDD. If i use cast from my mobile the name of the tv is KD 75 and not KD 55. So the ID is wrong. How can i get back my recordings?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi okalles,
as far as I am concerned, the recordings are bound to your TV. If you unplug the HDD and plug it into another TV of the same model, you can't play the videos (it is the same for my dads Samsung TV and my Philips TV).
Since your mainboard was exchanged, the HDD does now see your TV as a different one. I am certain it wouldn't change anything if they would have replaced your mainboard with one of a 55" TV.
So I am sorry to tell you that your recordings are unaccessable as far as I can tell.
@Kuschelmonschter might have some more insight on this topic and is pressumably the only person aware of a trick/hack (if there is any) to get back access to your recordings.
- Nic
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Fully agree. There is no trick or hack that I am aware of to circumvent the encryption.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I thought that if Sony can encrypt they also can decrypt. The case is an warranty claim. Bought tv 15 months ago.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
okalles wrote:I thought that if Sony can encrypt they also can decrypt. The case is an warranty claim. Bought tv 15 months ago.
No, it doesn't work like that. It isn't Sony decrypting, it's the algorithm. And the algorithm to be 100% (well.. ideally) safe needs to be able to decrypt only on the platform that made the encryption. It's the encrypting side owning the (highly hidden) encryption key, and once you replace the motherboard (or even just after resetting to factory settings) that key has gone, getting replaced with a newly generated (I think randomly) one.
It's the price of security, allowing a backdoor would render the encryption much less secure (since the key wouldn't be private but somehow public instead).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You still have access to recordings after factory resetting. Suppose the key is somewhere in the hardware..
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@Kuschelmonschter wrote:You still have access to recordings after factory resetting. Suppose the key is somewhere in the hardware..
Well, I tested it with the (broken) internal memory extension. After a reset it didn't recognize it. But thinking better about it it can be because after a reset it wouldn't be clean to use old data. I thought the key was tied to the Android ID, that at least on mobile gets re-created after each reset (so it says Titanium Backup on rooted phones). But sure, it must be in tied to the HW, then.
Then I think, for example, that the external disks (which is a recent feature) used as extended mass memory in the PS4, have the key tied to the PSN ID. So yeah, there are various options. As long as the key is not easily accessible by the public.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
So u mean that the Sonys service partner the company who put the new motherboard in my tv can do thet? And, do u think that the wrong name on the tv can be exchanges back to KD-55x from the wrong name KD-75x.Could This may be the reason for the problem.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@okalles wrote:So u mean that the Sonys service partner the company who put the new motherboard in my tv can do thet? And, do u think that the wrong name on the tv can be exchanges back to KD-55x from the wrong name KD-75x.Could This may be the reason for the problem.
No, the HW now is different, no one can do it. Encryption is for security (and in this case DRM/copyright protection), if the algorithm gets the encryption key from the motherboard the content of that hard disk is completely useless now. Unless of cracking the encryption key from a PC, but good luck with that...
Still yes, something is wrong with that KD-75. What does it says in the help (pushing the button in the lower left corner in the remote)? The model is written in the top-right corner. It won't help you with the encrypted data, but it shouldn't report a wrong model either. But yet again, they are two distinct issues.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hmm- Dont know what 2 do. Thought if i brought tv and hdd to service the workshop they could pair it together again.
