Where can Dynamic Labels be switched for DAB transmission to the KD-48A9? Common on so many Sony products including KDL-40HX853. Is Dynamic Labels Segment (DLS) supported on newer TVs. If not, what is the software fix. Need this for professional work.
Thanks
I'm not aware of this feature with the current TV line-up.
Maybe there's an app on Google Playstore that supports this function.
Do let us know if you find such an app, I personally haven't seen this on any of the current TVs either.
Hi birjohn, this feature isn't supported on that model.
