I own a 4K Sony 2015 android with twin tuner. When I start a HDD recording of any channel it is not possible to watch other channels with subscription (scrambled) at the same time. I can only watch free (no scrambling) channels during recording other channels.
It seems to be impossible to see other subscription channels during HDD recording.
Maybe this problem has been introduced with some of the latest firmware updates?
I recognized it too. It has unfortunately never worked and I doubt it ever will. It is also in my Bug-Tracker.
I have exactly the same problem with my TV KD-49X8305C - apparently no response from Sony, they know they have a problem, or they answer
this is not a bug, you can not record one channel while watching another, if one needs the CAM to be displayed (scrambled).
Manolo
Of course its a bug, otherwise its a major design failure. There should not be a problem for both tuners to use same scramble hardware, CAM, at the same time. Humax digital set-top boxes has done this for years.
Sony need to fix this or stop selling twin tuner solutions.
Both you guys can be right. It depends on how the CI is wired. If it is hardwired to tuner 1, we have a problem. This would be a severe design issue though.
It is true however that settop-boxes chose wisely, whether or not they send a TransportStream over the CAM, depending on whether the channel needs descrambling. If channel 1 on tuner 1 does not need descrambling (is FTA), the TS is not routed via the CAM, which can therefore be used for channel 2 on tuner 2.
There are even smarter solutions. Digital Devices can for example remux scrambled channels on multiple tuners into one single TransportStream, which it then sends to the CAM for parallel descrambling. Today's CAMs can descramble up to 32 or even 64 ES PIDs with a bandwidth of up to 100mbps. You can descramble quite some channels in parallel with that. It is even possible to add/remove programs in that mux on-the-fly without introducing glitches.
There is also a CI-PHY from SmarDTV which supports that from 2 tuner inputs. So basically 2 tuners can use one single CAM for descrambling in parallel. I don't even dare asking for something like that. Just for the basics...
Sony's solution in my opinion is no twin-tuner at all. All it can do is watch and record with 2 FTA channels. You can't even record 2 FTA channels, probably because when scheduling the recordings, the TV can't already know whether the events will be scrambled or not.
What I expect from twin-tuner that Sony does not deliver:
- PiP
- parallel recordings
- watch FTA while recording scrambled
