- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
October 2021
October 2021
DTS passhtrough bug on XH90/X900H on v6.1288
A would like to report a bug. After the recent v6.1288 update when I try to use PLEX the DTS passthrough is bugged. It sends bad audio signal that crackles. I've tried with another app and the result is same. The only fix is set Digital audio out Auto 1 to Auto 2. Could you please investigate? Factory reset did not solved this problem.
1 REPLY 1
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
October 2021
October 2021
Hi @kfkrisz It is probably best to contact Sony Support direct for your country or region. I’m afraid that nobody is going to investigate on the back of a post in this community of customers.
