hello i have a sony bravia kd55xe9305 and im wondering if i use the us firmware to download the dolby vision update would this work on my uk tv or would i lose the youview app etc? any help would be greatly appriceated im to impatient to check out dolby vision on netflix etc to wait
The US version won't install on your EU/UK model.
oh thats a bummer so we will just have to wait?
Yep.
Current Dolby Vision firmware update in the states has caused huge upset, it does not work via HDMI or USB, there is a “format war” within the Dolby Vision profile spec 🙄 European update is scheduled for February, for all devices.
@Suddzz wrote:Current Dolby Vision firmware update in the states has caused huge upset, it does not work via HDMI or USB, there is a “format war” within the Dolby Vision profile spec 🙄 European update is scheduled for February, for all devices.
its feb lol do we have a date ?
i also have a sony X700 waiting for the dolby update
I heard it had been put on hold or delayed?
delayed ?
i know they have had a HDMI issue and i believe that is sorted ...
@benjy86 wrote:I heard it had been put on hold or delayed?
If you read U.S. forums you will find out that the FW had quite some severe issues.
