Hello
I would like to play Dolby Atmos via HDMI/ARC on KD-70XF8305.
When I use NETFLIX on TV, Dolby Atmos is present on my Yamaha RX-V583.
But when i use Android Kodi or VLC (from GooglePlay) to play video from USB HDD, then on my receiver is only DolbyDigital.
Is any option to fix it ?
Thanks
Hi walsh441,
Welcome to the community.
I'll see if I can find some advice for you about this. Maybe someone else in the community can help in the meantime.
Thanks,
Pascale
Hi walsh441,
I've looked up the sound processing for this TV and found only the following: Dolby™ Digital, Dolby™ Digital Plus, Dolby™ Pulse.
So i guess it doesn't support Dolby Atmos.
Cheers,
Almou_10
