Hi can anybody advise a Good Dolby Amos sound bar for my new Sony XR55 x90J full array 4K TV
regards
I have a Sony ZFT9 with the rear speakers and it’s amazing! Think it’s the best one Sony do. This one comes with a subwoofer and I’d recommend making sure you get a sub for whatever soundbar you go for
Hi Thanks I have been looking at at that sound bar
regards
