If I connect a soundbar (ht-sf200) to the TV (kd32w800), Can I adjust the soundbar volume by TV remote?
Thank you
Yea that kinda seems conflicting between the information in the specification page, and the manual itself.
I'd say we won't be able to confirm unless we actually test it!
Hey there,
I believe that the TV supports HDMI CEC, so in theory I think you can do it: https://bit.ly/3GXmBqs & https://bit.ly/3rAeJoh
Hope it helps.
Thank you, SkyNet
So, if I find that HDMI-CEC field on TV specification is 'No',
even it is using Bravia Engine, it still not support Bravia Sync.
Am I right?
Tony
