Dear,
Does anyone know if the model KD-55XE9305 will be compatible with Disney +? Currently I see the app in Sony Select, but according to the app my device is not compatible!
Using the Google Play Store on my TV, I see no app already available, would it be because Disney + in Belgium can only stream as from 15/09?
Frederik.
Hi Frederik,
If Disney+ is not yet available in Belgium you won't find the app in the Play Store.
Please try again after Disney+ is available in Belgium.
