With the nougat update I now see TV programmes in a half screen mode when I select 'Settings' and TV programmes also run in the background on the home scren. This is really annoying. When I am changing settings I don't want to be distracted by a TV programme running to the left of them.
How can I disable the 'half screen' mode that nougat introduced?
Thanks
Hi there,
Can you tell me if you mean that the picture displays in a small screen in the corner?
Cheers,
Sean Mc
