I had noticed this a few days ago, but I thought it was my mistake.
Today had this issue again.
Cannot specify the cause or app. Re-boot is not the cause.
New notice:
Disabled WiFi is unfortunately enabled by simply entering Home Screen - Network Settings and WITHOUT selecting Wi-Fi.
Try this:
Hello, I'm sending you the same piece as below in case you are able to help. I know it's a bit late but I've just seen your ad and, if possible, would be keen to hear if you solved the problem of turning off both wi-fi and Bluetooth. I'm interested because I now want to buy a new Sony 4K OLED TV (55 inch) but I do not want wi-fi or Bluetooth, preferring instead to hard wire everything due to EMF. Now (Dec 2019) I see that both can actually be turned off but I wouldn't want to buy a TV where they keep switching back on automatically. I don't use apps, voice activation or any thing like that, just basic stuff as minimal as possible so perhaps there's something I could switch off or similar to prevent the switch on happening. Anyway, I thought I'd write as I'd be interested in your thoughts and whether or not you've made progress in your deliberations regarding your problems.
Many thanks
My best wishes
Hi
I have just bought sony 48 inch oled smart tv 2020 model. But this tv is giving out to much EMF. How can disable all the EMF's
Thanks
Hi
you can feel the EMF from sony smart tv, because it attacks parts of the body when you sit for a few minutes in front of the tv.
regards
Not sure how objective that method can be considered. But if you let me know the model number of your TV, i'll help you disable any Bluetooth/WiFi connection if applicable.
Win_88
Hi
Thanks, my sony tv model is :
KD48A9BU
Sony Smart Tv 48" OLED
Need to know how to disconnect
The built in wifi/bluetooth emitters on the motherboard and still be able to connect the ethernet cable from tv output to router for internet.
Hi @asrehma50
I'm afraid I can't help you disconnect anything from the motherboard. Does this mean you already have them set to OFF in the settings?
Win_88
