Can anyone explain the difference between KD55AF8 -OLED and 55XF8505 4K? It`s a big pricedifference but what more do I get on KD55AF8?
They use completely different panel technology. Af8 is an oled while xf85 is an edge led LCD. If you do not know the difference by 2019 maybe is better you try searching the internet a bit
