Do all of us have the option to go in Developer Functions or only specific models?
Previously reported method does not work for me:
https://community.sony.gr/t5/televisions/2015-bravia-android-tv-issues/td-p/1949079/page/523
KD-55X8508C
I did this before. Problem is with CAPTCHA code. Google translator is not working there:)
Additional:
1) Sony Satellite Channels Editor:
http://4pda.ru/forum/index.php?showtopic=731708&st=280#entry56076702
source code: https://yadi.sk/d/XQLMuPOg33aeZH
2) Sony Tv Remote:
http://4pda.ru/forum/index.php?showtopic=738311&st=100#entry56076625
source code: https://yadi.sk/d/Vx3-3RkJ33aeYW
And I really hope that it is the source code of these programs will allow programmers to do other interesting programs for Sony (hope that they will be free). No rights and copyrights for a not save, do whatever you want.
in private messages: i can register you account in this (4pda) site and send login-password
You need send my you wanted nik and email (or translate screenshot capture) - Only private messages - this is - OFFTOP.
I try to write short instructions. Sorry for the translation.
and create topic in more native site: http://forum.xda-developers.com/android/software-hacking/network-adb-extension-windows-explorer-t351...
1) Turn on your TV - developer mode.
1.1 Go to the "Settings" section and select "About phone (or on TV)"
1.2 find the "Build Number", click on it seven times (the system will report that enabled mode)
1.3 In the setting will be a new item - Developer Mode
2) In option "developer mode" enable - "remote debug"
3) After install my application - in context menu click - "Preferces" and type IP Adress (port 5555 not change - this is ADB port)
4) in context menu click - Connect. In TV or Mobile message appears for authorization to operate the device with your computer - click allow.
Amen, in Windows Explorer, you should see a Android file system.
nuances and more details - read forum
