Hi guys
I’d there a way to make the tv power on straight to you view? It currently always comes on to hdmi1 then I have to manually select “TV”. It would be great if it would start up with You view every time
Cheers Jon
It’s intended to come on on YouView, and indeed the ability to choose any other default power-on is disabled when you use the YouView UI.
So at a guess, whatever is plugged into HDMI 1 is using CEC (BraviaSync) to switch to itself.
What is connected to HDMI 1?
How are you powering on the TV - with the Sony remote, a multifunction remote like the Harmony, or via another piece of kit?
What happens if you unplug the cable to or from HDMI1, as an experiment, and then power the TV on - does it come up as YouView?
If it is a CEC issue, this can be solved by turning off CEC on one or both devices, but that has other implications that we need to consider, so we need to know what’s plugged in to HDMI 1 to best advise you.
Thanks for your reply. It was as simple as taking the HDMI cable out of 1 and putting into 4. Now when I power on the tv it starts with what ever was last selected rather than constantly jumping to hdmi1.
thanks for your knowledge
Cheers Jon
