It’s annoying, don’t know what it means, but learnt how to set it to off, but it just keeps on switching back on. Any ideas? Thanks
Thanks, i now know what it means but it is bothering me and can’t seem to switch it off + i haven’t added any mobile device??
Strange... Among the settings, but I have no way to show you exactly where, you might have activated Remote Start, if so try turning it off. First of all just try to restart Android TV, yours should be an Android TV, by holding down the Power button on the remote control.
Manolo
You are a brilliant person, you have solved it, went into settings and turned off picture reset and hey presto, the light has gone, thank you very much x
No, You did everything you -)
Manolo
Lol, we'll share the glory. Have a great day
