Hi, can anyone help, i have the 49xe9005 tv with ubp-x800 and the str-dn1080, when the bluray is in operation, is there anyway to control it with the tv remote, only the volume seems to work and not the stop,play, forwad etc same for the reciever remote?
@davygravy wrote:A quick question, when you turn off your x-800 does your auto switch back to TV? ,Cheers
Hi @davygravy. Using the Action Menu to power off the X800 it returned the TV to the last Digital TV programme. Also the same powering off using the X800 remote.
Cheers, are you using inbuilt TV or set top box for TV, I'm using a you view box, and I'm sure it auto switched last week when I turned x800 off now amp just stays on Blu-ray, cheers
@davygravy wrote:Cheers, are you using inbuilt TV or set top box for TV, I'm using a you view box, and I'm sure it auto switched last week when I turned x800 off now amp just stays on Blu-ray, cheers
Hi @davygravy. It doesn’t matter, inbuilt TV or set top box (Sky Q) it returns to the last thing I was viewing. Mind you I am connected direct to the TV and not passing through an Amp. My Amp is connected to the TV using the ARC HDMI because it does not support 4K pass through.
