My remote does not work, I have tried it on my other Sony’s and it works fine. The orange light is on constantly. I think it 1 or 2 reasons.
1. Turned off during a software update?
2. Timer set
either way I can’t get it to do anything. I have tried a hard reset about 50 times and that doesn’t work.
Help please
scott
What model TV are you referring to? What software version is it on?
Hi, it’s a KDL-32WE613 but I don’t know what software it is on as the remote doesn’t work so I can’t see what software it is on. I can only turn it on using the the buttons on the back
Use this article to make sure that the remote is the one not working and not the TV's IR receiver.
