I'm trying to connect my Bravia KDL-40R553C to the internet via a mobile hotspot using my Samsung Galaxy A70 but it won't work. It works fine on my Android Kindle Fire. The phone won't find the TV. Is it possible to connect via a mobile hotspot rather than a router? If so what am I doing wrong? I have no router as I'm in a static caravan on the Cornish coast.
Regards
Geoff
Yes, the TV can see the network (Android AP4990) with full signal strength and asks for a WPA key. I'm assuming this would come up on the phone if it could see the TV
Regards
Geoff
If the problem is the Key (Password), you can find it in the Tethering (Hotspot) settings.
The TV comes up with a screen headed 'network set-up - wireless security'
I enter the key/password which is 4 lower case letters followed by 4 numbers. I then click on enter. It then tells me to press enter on my remote 'to enter your security key' and it just returns me to the previous screen
Regards
Geoff
I've seen where I went wrong,
Thanks so much for your help,
Regards
Geoff
Just one more thing Marino, I am now connected to the internet and can get Amazon Prime Video, Netflix, BBC iPlayer and YouTube.
Can I add ITV Hub and my IPTV app?
Thanks and regards
Geoff
I'm afraid, we'll have to wait for someone from the same Country to get an answer.
