x
Connecting Freesat box to Sony Bravia
SOLVED
profile.country.GB.title
bobjillclark
Explorer
What HDMI port should I use when connecting my Freesat box to my Sony Bravia KD43 TV and what setting should use for that port. Currently the picture and sound quality are nothing like as good as when viewing input from the internet.
1 ACCEPTED SOLUTION
Accepted Solutions
bobjillclark
Explorer
TV now working fine with Freesat connection via Port 4 with enhanced setting. thanks.
8 REPLIES 8
LightFoot
Specialist
Hi @bobjillclark   Would you please tell us the full model number of your TV. There are many variations of KD43. Also which Freesat box do you have, just HD or the newer 4k box.
bobjillclark
Explorer
The TV is KD43X75WLPU and the Freesat Box is a Recordable 4K 1TB
Changing the HDMI cable to Port 4 and setting it to enhance mode (I think) does seem to made an improvement, but the Suppliers engineers are now going to call in on Thursday to check it over.  Can I use my internet connection to get a full TV Guide like I have on the Freesat box.  I don't have a conventional aerial.
Thanks for your help.
Bob
jumpedfromtoshiba1
Explorer
I think the Arris 4K box automatically outputs the picture in HDR and there numerous complaints about this, it may be possible to select standard on your HDMI input on the TV to get a better picture.
bobjillclark
Explorer
Thank you for your help, I will talk to the suppliers engineers when they come tomorrow.
Donny1
Explorer
Have you found the answer.
Donny1
bobjillclark
Explorer
Not sure which port to use for my Freesat Hymax box
LightFoot
Specialist
Hi @gerry.amdor   To help you we need to know the full model number of your TV and your Freesat box.
