Hi - I have connected a Bose soundbar to my Sony KDL-46HX823 using the optical cable connection.
Sound on any HD channel is great.
There is NO sound on any other channel that is NOT HD.
I cant use the std Audio Out on the TV 'cos the connector is not compatible with the Bose cable.
Can anyone suggest how to get sound down the Optical spout for non-HD channels?
Many thanks
Peterthepainter
Hi Peter,
Thanks for joining and reaching out to the community. You'll find a help guide for your TV here that may help you to work out what is compatible and/or figure out other options.
Best wishes,
EdwinaU
