I have read a few things on here but i have just had a Adapter which i connect to my 3.5 jack and powered by
the u.s.b slot as its a rechargable one,it all works and lights up but i need to set up the 3.5 jack for the sound
through Headphones only using the 3.5 jack plug then when i know its set up i can pair them to it.
I have turned Headphones on through setting but no sound even if i just put corded ones in the 3.5 jack.
Thanks
Hi @jace1969,
maybe the headphone volume is turned down to 0%.
It has to be controlled trough the menu on all TVs I have owned so far and is independant from the normal volume adjustments.
Another reason could be, that your BT-adapter and the headphones you are trying to use have a TRRS connector, while they need to have a TRS-connector.
You can see the difference in the images next to this wikipedia article: https://en.wikipedia.org/wiki/Phone_connector_(audio)
- Nic
