Hi all, I have a 55XH9505 tv, and I have removed two items that were connected to the tv, ie, Humax BT box and a sound bar ( upgraded so I don't need them) my problem is.... Can I delete these obsolete items off the page where the connected devices are listed?? Because I have too many devices listed now, and half of them are still showing that I don't use, would a 'soft' reset do the trick? If not, could one of you guys give me some advice. Kind regards muvoda.
Check if you can edit them here: Press the HOME button, then select [Settings] — [Watching TV] — External inputs
Hi @Anonymous Thank you for your response to my query, I have tried that thanks and it does not delete the items that I once used, they are still showing, I am at my wit's end with it, so apart from doing a full factory reset ( which I would rather not do) I think I will just have to suck it up!! I did try a 'soft reset' but it didn't make any difference. Thank you again for your input. Regards muvoda.
Hey @muvoda,
In the external inputs menu, there's an option called ''Manage Inputs'', you can edit the inputs, change the naming and I think remove them as well.
Hope it helps.
Hi @Anonymous, thanks for taking the time to respond, I have had a look at that, but all you can do is 'Hide' or 'show' you cannot delete, and ironically, the unused devices that I have got rid of are showing (STILL) in the sync device's menu, weird, I really don't think there is anything else that I can think of, apart from a factory reset and you know what I feel about that, so I am just going to leave be. So thanks again. Regards muvoda.
This may be a far fetched idea, but can you disable Bravia Sync, do a soft reset, and see if they're still there or not before enabliling it once more?
Hi, that is an excellent idea, I don't know why I never thought of it, I will definitely have a go at it and post my results, thank you so much @Anonymous.
Hopefully it's not just an idea, and it can actually work! Waiting to hear the good news from you, fingers crossed.
Hi, I will post at the weekend because of work issues. Cheers muvoda.
Sure, take your time and hope next time you have good news for us!
