Hi there,
I am looking to get a compatible DVD player for my mum's SONY KD 43XF80xx TV. We've had some issues finding a compatible one.
Does anyone know what sort of DVD player we might need? Or what sort of specifications we need to look out for?
I found the user manual online here which shows on p10 the component parts for consideration - I wonder if I just need to search for these parts when looking for the DVD?
https://www.sony.com/electronics/support/res/manuals/4733/4733199EM.pdf
If anyone can provide advice that would be really helpful!
All best,
Charlotte
The TV has HDMI ports that you can see on p10, so getting a player that outputs via HDMI is really the only thing you'd need to consider.
