1. TV goes off with right colour temperature Expert 1
I turn it off , and, after 8 minutes I turn on the TV... It's gone, it's all bluish.
I have to manually change it in the menu or change to:
Another HDMI
TV
App.
Did two factory resets and I won't do no more!
This is incredible. It's a basic thing. The TV has to retain its color
Configuration. I've never seen anything like this in my entire life!
2. The red optical light of the toslink connector for audio on the back of the TV doesn't go off.
I am just wondering if this nice piece of engineering is always online...
Can anyone confirm to me that, after 8 minutes off, the red toslink light goes off on the back of the TV, please?
Thank you.
here @ sony Community germany there are at least 2 reports about THIS certain bug
one is mine
it´s not a shame a firmware has such a bug,
its a shame for this company NOT fixing such an elementary function - really bad
i´m also convinced, this bug does have more model ranges....not only the w80c series
i owned so many TVs in years past, and i never had such a problem....
maybe we only misunderstand Sony firmware design
perhaps they think:
do you have certain model ranges, where you can confirm THIS neutral colour temperature bug ??
by the way it´s pretty funny to see the cinema pro preset mode also suffers this bug.
*facepalm*
I didn't have that bug on v3.533 on my W75C as german thred suggest. This came with MM.
After reboot coolor is correct. After some standby time it is not. If I turn on TV I can see that's is wrong in my HOME screen or in settings but as soon as I switch to digital TV it switches to the right one.
I know I had this problem before too. It would switch to Neutral color temp after deep sleep even though the settings still indicated Expert1. It had to be set again to take effect. I still had this on my "to check" list and due to many reports I tried to reproduce it yesterday.... but I failed... (I checked with a multimeter that the TV entered deep sleep)
So it either got fixed for my 4K HDR model in the meantime or it is just some race-condition which the Sony crap software on those TVs has plenty of.
