1. TV goes off with right colour temperature Expert 1
I turn it off , and, after 8 minutes I turn on the TV... It's gone, it's all bluish.
I have to manually change it in the menu or change to:
Another HDMI
TV
App.
Did two factory resets and I won't do no more!
This is incredible. It's a basic thing. The TV has to retain its color
Configuration. I've never seen anything like this in my entire life!
2. The red optical light of the toslink connector for audio on the back of the TV doesn't go off.
I am just wondering if this nice piece of engineering is always online...
Can anyone confirm to me that, after 8 minutes off, the red toslink light goes off on the back of the TV, please?
Thank you.
Of course Sony did'nt fix it At least on my w805c the issue still remains on v3.865. Really annoying.
so next 2 reports about this incredible bug
reported by knirps87 and dswatcher82
dswatcher82 own the Sony w855 top model with 75"
a ~3000 € TV !!!
https://www.heise.de/preisvergleich/?phist=1246874
so w75c w80c w85c series customer still suffer under bluish picture quality
another workaround founded by DSwachter82
when TV is on and use wrong colour setting
>>>press "help" key on remote control and go back (exit)... of course EVERYTIME you turn your SONY Bravia on
so hello again!
new firmware is out there
File Name
Does it solve your colour temperature problem finally?
Who wants to be the human guinea pigs?
Hi @sonyw805c
No reported issues to do with the installation of the new firmware. However if your hoping for this fault to be fixed, its unlikely - although test it out and report back here ?
Hi Q,
i won´t do sony updates anymore because i can´t go backwards after such an update. I would go back to 5.1 if i can. (due to faster system booting)
For sure I will only update this TV anymore if this issue and the "channel deleting" issue will be fixed.
The last 3 updates didn´t solve this 2 bugs.
