I own a sony bravia KD-43X81K google tv.
The Channel List export to usb stick won't work - just gives a message "Export failed. There may be a problem with writing to the USB device."
Have tried multiple devices, and have formatted FAT32 and exFAT on the computer, also formatted using the TV.
Anyone got any idea how to make this work? I can't currently use the smartphone channel editor as it's not available for iOS.
Thanks.
Hey @Flurbyrock, are you using Windows PC or Macbook? I believe you need to make sure to follow the system requirements here: https://www.sony.co.uk/electronics/support/lcd-tvs-android-x80k_x81k_x82k-series-43-75-/kd-43x81k/do... & https://www.sony.co.uk/electronics/support/lcd-tvs-android-x80k_x81k_x82k-series-43-75-/kd-43x81k/do...
I also came across this link: https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs-android-/kd-43x81k/article...
Hope it helps!
