- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
channel edit listing
hi guys I just noticed that my option to edit the channel listing options in satellite won't work .
the option is still there but it wont allow me to click it . any idea what to do. as far as I'm aware its on freesat built into the tv.
cheers all
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Try disabling YouView if you have it enabled.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Sent from Hotmail Email App for Android
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Ive had the same problem. It seems to let you arrange the channels once only after a retune, then it greys the option out.
Ive found a workaround, I use favourites and arrange the channels on there exactly as I want them. This also has the added benefit of being able to view the programme listing on freeview to decided what to watch then press the “tv” button and choose favourites (Ive renamed mine as satellite list) then select the channel you want.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
cheers pal that's seems to be the best option as even after a rescan the option to list the channels seems gone but favourite is working fine cheers pal 👍
