Just noticed that all my catch up apps are missing and are not in the app store.
Have they gone for good or can I do something to return them on the KD-55A1?
Hi @DumfriesDik
1. Is YouView enabled.
2. Are you looking in Sony Select.
3. Have you tried a soft reboot (hold the remote power button down until you see Restart).
4. Are you on the latest software (below).
5. If all else fails, have you tried a factory reset.
Firmware update to v6.7220 | Sony UK
