Hi Sony!
I try to mirror an IPhone to KD-43FXC7005.
When I select the TV-link on my IPhone I am requested to enter a code. - Which code?
Regards
Henning
Apart the tv model that should be KD-43XF7005, if I am right you have a non-android tv and there is no way to implement the proprietary airplay protocol to mirror an iPhone. You should buy an appleTv for that.
Why did you expect to mirror an iPhone on your tv?
