I have an XR50x90JU from Sony which I have connected to my Panasonic Home Theatre System SA-BTT370.
My problem is that I am not able to use this system anymore because the Optical-In or ARC does turn on the
AUDIO-SYSTEM but the audio is silent, no sound if I connect another device like the Sat receiver or Cable receiver.
If I use the Panasonic SA-BTT370 which is also a Bluray DVD player it turns on the AUDIO-SYSTEM and delivers the sound through the SA-BTT370.
I have tried everything, it does not work. My old Sony was able to work with this device.
Panasonic is using VIERA to link the systems, and I am quite sure that the settings are correct for both devices.
Has anybody any idea how to fix this?
Thanks
Joachim
Hey dublinrover, I would contact the support directly if I were you instead of going through all of this hassle..
