I got a software update on my 43XE8005 today and now I can’t find any of the catch up stations like bbc I player, channel four catch up etc. how can I find them again please?
Hi @Irimais65 If you now have Oreo then you will find that all the Players are now on Sony Select. From the Home screen click on Customise channels and ensure Sony Select is turned on.
