Hi,I recently purchased the SONY KD-49XF90 or X9000F in my region. I wonder if possible to enable audio outputs throught USB port to amplify external speakers or headphones like smartphones or laptops, if there is an app on GOOGLE PLAY STORE to enable this function? Is the only external output is the 3.5mm jack & AV combo jack or optical? Thx.
Hi wilson036,
Welcome to the community.
I'll look into this for you and see if I can find out. Someone else in the community may be able to advise in the meantime.
Thanks,
Pascale
Your model should be able to connect audio devices also via Bluetooth.
Manolo
And don’t forget ARC.
But why USB particularly, @wilson036 ?
Hi Wilson036,
I don't think this is possible via a 3rd party app.
Cheers,
Tenneen9000
