Can I get iplayer on Bravia KDL- 37EX503? If so, how?
@jumidgl45 wrote:Can I get iplayer on Bravia KDL- 37EX503? If so, how?
This is not an Android set (so you should really be asking under ‘Other’, not ‘Android’) and though this set has internet connectivity, it seems limited to playing videos. But on the bright side (sort of) any iPlayer it did have might now be rather old.
But with four HDMI sockets, you should be able to accommodate a NowTV stick (£20 one-off purchase, no need to subscribe if you don’t want to), which will provide a panoply of up-to-date internet apps over wifi, including all the major broadcasters’ players.
