Trying to connect a SONOS Beam Gen 2 to a KE-75XH9096 TV with little success.
The Beam doesn’t show up in the device list - hence It can not be controlled via the TV remote.
The Beam is connected to the TV eARC with the cable that came with the Beam. The only other device connected is an AppleTV. There is sound but I am just not able to control the Beam from the TV remote
Hey,
I'd say that the only logical answer to that is Bravia Sync is made to work with Sony devices, which doesn't include Sonos of course, maybe that's the reason?
Try to disable it and test it once more.
Cheers.
