Somehow restricted profile got set upand I have no idea what the password is found several fixes but none worked. I need to perform a factory reset but cannot unless restricted profile is disabled. Is there a master password that gives me access or a workaround.
Hi Sugarfeet,
Welcome to the community. The Sony website is experiencing some technical issues at the moment and I'm having trouble finding the manual page for your TV.
Please try searching the Q&As and the manual for your TV via the Sony website for 'restricted profile'. If no luck,
just call Sony Support on Wednesday morning.
Thanks,
Pascale_F
