Just re-connnecting my Bravia TV to the WiFI (after the internet was interrupted briefly yesterday). After entering the correct WEP password I keep getting an error message stating "number of characters is invalid". I see this has come up on other queries but I don't see the solution. What do I need to do???
Most likely you've entered the wrong password.
Please verify the correct password and the correct connection method.
Very few networks use WEP, I think you might be choosing that by mistake (if it's the default), most networks use WPA/WPA2.
