- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Bravia Sync
Hello,
I have a KD-43X8305C TV, a HT-XT1 soundbase, a Virgin Tivo box and a Sony BluRay Player.
The TV and soundbase are conenected by optical cable and a hispeed HDMI cable from the soundbase 'out' port to HDMI 4 (ARC) port on the TV. The BluRay player is connected from by HDMI to a soundbase HDMI 'in' port. The Tivo box is connected by HDMI cable to the HDMI 2 port on the TV. Before I went on holiday about a month ago this set up worked perfectly, with the Tivo remote set up to switch the TV and soundbase on or off together, and to control the sound on either the TV speakers or the soundbase, depending on what output the TV was set for. Since returning from holiday, I can't get the TV and soundbase to sync properly so I now have to use three remotes. Also, the TV output to the soundbase keeps switching off and back to TV speakers, necessitating switching the soundbase off and back on. I hear there has been a Sony firmware update whilest I was on holiday which may have affected things.
Any ideas anyone as this driving me nuts.
Thanks
CC62
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
In your description you have an optical cable AND a HDMI cable connected TV from the HT-XT1 - if this is the case, remove the optical cable - it is not necessary and can cause 'device confusion'.
Also, reboot the TIVO - it has been known to cause HDMI issues and a reboot fixes it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
The set up described has worked perfectly previous to the last month. If I remove the optical cable I get no sound at all from the HT-XT1. I’ve tried a TIVO reboot but that hasn’t worked.
I understand there has been a recent firmware update for my TV - could that be causing an issue?
Regards
CC62
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
I think we need to start over and take things from the top.
Yes there was a firmware update to your TV just recently, version 3.885 was released. So I suggest doing the following.
- Turn TV OFF completely
- Remove the Optical cable
- Ensure that the HDMI cable is connected to the HDMI-ARC port on the TV (it should be HDMI4 on your TV)
- Ensure that the other end of the HDMI cable is connected to the HDMI-OUT port on the HT-XT1
- Turn TV on.
- Ensure that the TV Speakers are set to "Audio System"
You 'should' be getting sound now. If not, considering that there was a firmware update and it happened after that, do a complete factory reset of the TV (leave the optical cable disconnected). Instructions HERE.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Regards
CC62
Sent from my iPhone
