I have an older (2016?) KD-49XD7005 and whilst it has all I want for now, the remote doesn't have the Voice Command facility. The TV DOES have the Voice app in Settings.
Can I assume that a replacement Commander Remote would be compatible seeing as the TV seems ready to go?
Thanks 🐵
Hi @winchester12g As far as I can see you are ready to go as your TV is included in the applicable models. I have an older model (2015) and it works brilliantly with voice search. However I have a Sony Voice Touchpad remote so can’t say 100% that a voice remote will work but the chances are very good.
Edit: This article shows you how to pair the voice remote to your TV.
https://www.sony.co.uk/electronics/support/articles/00199201
Thank you!!
Hi, we have the same KD-49XD7005 model.
Which remote did you purchase as there seems to be a few available?
Here's a few I've found RMF-TX300U RMF-TX220E RMF-TX310E
