x
jobbybhoy
Explorer
Bravia Kdl50w 805c
i have just discovered my tv's front led blinking red 6 times over and over, the tv works fine and the firmware is up to date, does anyone know what this means.
thanks
2 REPLIES 2
Anonymous
Not applicable
Hi there
Normally the blink codes indicates a hardware fault.  I dont have access to the service manual for this model tv to find out what 6x blinks mean.  Blink codes can be different from year to year and model to model, so i cant give a definate cause.
My advice is to contact your retailer and report this fault, even though the tv is working....At the moment.
profile.country.GB.title
frogger38
Member
@jobbybhoy Mine did that! I unplugged it for 5 minutes and it's been OK for a few weeks.
Product is is Sony 2015 KDL 43W805C Android TV, UK Model with YouView, purchased Sept 2015.
