Hello
I just bought a 49 xf8096 4k model TV, and i was wondering if there is a way that i could make the image smaller (say 32 inches). The rason is, that for my small living room, the tv is to big for my 2 year old daughter and wife. But for my home theater use it is the best. So i want to swap aruind the image size.
Thank you in advance.
PS: i saw this:
Edited [Link removed]
but it seems that i dont have that oprion on my Android TV.
Hi Mocians,
Welcome to the community.
We'll look into this and let you know what we find out. Meanwhile, some of our members may be able to offer some tips.
Best wishes,
Ed
Hi mocians,
I think the possible options for adjusting the viewable area would be in the Display section in the settings menu. You can check the most suitable options to you using this menu: https://bit.ly/2RAuAjv
Vanilla_
