hi since the oreo 8 update my tv seems to have a mind of its own, firstly after the update my tv would randomly freeze then reset itself, after a few times i got bored so i done a factory reset to try and rectify the problem that worked but created a new issue,Now my tv keeps turning itself ON randomly can someone give me a solution please
Hi there,
So I can try to help, can you let me know if the TV turns on at regular intervals, such as 30 minutes or an hour?
Best wishes,
Sean Mc
hi cheers for your reply but i found out what the issue was,it was in network/remote start that was set to the on position that was turning the tv on
